Ga door naar hoofdinhoud
Braun M1000 gearbox Replacement
Luca V
Luca V en 2 andere bijdragers
Voor het laatst geüpdatet op August 1, 2024
20 minuten
Eenvoudig
Door de gemeenschap gemaakte handleiding
How to replace the gearbox with original spare part.
  1. Braun M1000 gearbox Replacement, Open the plastic enclosure: stap 1, afbeelding 1 van 2 Braun M1000 gearbox Replacement, Open the plastic enclosure: stap 1, afbeelding 2 van 2
    • Put the mixer in a vise as shown in picture and gently press it. You can use plastic vise jaws to avoid scratching the case.
    • Increase the vise pressure and pull the handle until it pops out. It is important to apply the correct pressure to release the plastic hooks.
  2. Braun M1000 gearbox Replacement, Open the gearbox: stap 2, afbeelding 1 van 3 Braun M1000 gearbox Replacement, Open the gearbox: stap 2, afbeelding 2 van 3 Braun M1000 gearbox Replacement, Open the gearbox: stap 2, afbeelding 3 van 3
    • Unlock the gearbox cover using a T15 torx key
    • Remove the gearbox cover by pressing it as show in the picture
  3. Braun M1000 gearbox Replacement: stap 3, afbeelding 1 van 3 Braun M1000 gearbox Replacement: stap 3, afbeelding 2 van 3 Braun M1000 gearbox Replacement: stap 3, afbeelding 3 van 3
    • Pull the central gear to remove it from the crankshaft. In the picture you can see the crack in the gear that was causing excess noise.
    • Replace the gears with the spare parts. The central gear needs to be inserted with some force on the crankshaft. A small hammer can be used to get the central gear in place.
  4. Braun M1000 gearbox Replacement: stap 4, afbeelding 1 van 1
    • Put the gearbox cover back in place with the torx screws.
    • Push the plastic enclosure back in place. Press gently until it clicks in place.
Eindstreep
Luca V
194 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 1,181
