Bose SoundLink III Bass Speaker Replacement
Inleiding
Ga naar stap 1If you are experiencing any audio issues with the lower frequency sounds (the bass) such as distortion, muffling, quietness, or total absence of sound, you may need to replace your bass speaker.
Wat je nodig hebt
Gereedschap
Toon meer…
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Gently peel back the adhesive padding on either side of the inner back panel.
Remove the four 12.5 mm screws using a Philips #2 screwdriver.
You will now be able to remove the bass speaker.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Where can I buy this bass speaker (Bose SoundLink III)?
