Ga door naar hoofdinhoud
Blackstone Cascade Pro Fan Replacement
Wat je nodig hebt
  1. Blackstone Cascade Pro Fan Replacement, Fan: stap 1, afbeelding 1 van 3 Blackstone Cascade Pro Fan Replacement, Fan: stap 1, afbeelding 2 van 3 Blackstone Cascade Pro Fan Replacement, Fan: stap 1, afbeelding 3 van 3
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: stap 2, afbeelding 1 van 2 Blackstone Cascade Pro Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: stap 3, afbeelding 1 van 3 Blackstone Cascade Pro Fan Replacement: stap 3, afbeelding 2 van 3 Blackstone Cascade Pro Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: stap 4, afbeelding 1 van 2 Blackstone Cascade Pro Fan Replacement: stap 4, afbeelding 2 van 2
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: stap 5, afbeelding 1 van 3 Blackstone Cascade Pro Fan Replacement: stap 5, afbeelding 2 van 3 Blackstone Cascade Pro Fan Replacement: stap 5, afbeelding 3 van 3
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Conclusie
Mohamed Mallah
148 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 292
