Ga door naar hoofdinhoud
Black and Decker Pivot Plus PD600 Pivot Button Disassembly
Ryan Angelich
Ryan Angelich en 10 andere bijdragers
Voor het laatst geüpdatet op December 29, 2022
10 - 20 minuten
Eenvoudig
This guide will walk you through the process of removing the pivot button on the Black and Decker Pivot Plus PD600.
The pivot button may need to be removed and checked for contaminants if problems such as jamming of the button occur.
No special skills or tools are required for this disassembly.
Wat je nodig hebt
Gereedschap
  1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: stap 1, afbeelding 1 van 2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: stap 1, afbeelding 2 van 2
    • Locate the pivot button screw labeled with a lock symbol.
    • Remove the screw with a Phillips #1 screwdriver.
  2. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: stap 2, afbeelding 1 van 2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly: stap 2, afbeelding 2 van 2
    • Set the screw to the side.
    • Remove both sides of the button from the screwdriver.
    • You will be left with three pieces: a black piece with a lock on the front, a circular orange piece, and a spring.
Conclusie
Ryan Angelich
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-15, Maness Spring 2013 Lid van Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,241
