Ga door naar hoofdinhoud
Bissell Air180 Fan Replacement
Aleah Ramos
Aleah Ramos en 2 andere bijdragers
Voor het laatst geüpdatet op December 19, 2022
8 minuten
Gemiddeld
The fan on the Bissell Air180 is a vital component in air purification. With propellers constantly in motion, it can be easy for something to get stuck or cause this component to malfunction.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Bissell Air180 Fan Replacement, Air Filter: stap 1, afbeelding 1 van 2 Bissell Air180 Fan Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Fan Replacement: stap 2, afbeelding 1 van 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Fan Replacement: stap 3, afbeelding 1 van 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Fan Replacement, Power Supply: stap 4, afbeelding 1 van 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Fan Replacement: stap 5, afbeelding 1 van 3 Bissell Air180 Fan Replacement: stap 5, afbeelding 2 van 3 Bissell Air180 Fan Replacement: stap 5, afbeelding 3 van 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Fan Replacement, Control Buttons: stap 6, afbeelding 1 van 3 Bissell Air180 Fan Replacement, Control Buttons: stap 6, afbeelding 2 van 3 Bissell Air180 Fan Replacement, Control Buttons: stap 6, afbeelding 3 van 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Fan Replacement: stap 7, afbeelding 1 van 2 Bissell Air180 Fan Replacement: stap 7, afbeelding 2 van 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Fan Replacement: stap 8, afbeelding 1 van 2 Bissell Air180 Fan Replacement: stap 8, afbeelding 2 van 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Fan Replacement, Fan: stap 9, afbeelding 1 van 3 Bissell Air180 Fan Replacement, Fan: stap 9, afbeelding 2 van 3 Bissell Air180 Fan Replacement, Fan: stap 9, afbeelding 3 van 3
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Fan Replacement: stap 10, afbeelding 1 van 2 Bissell Air180 Fan Replacement: stap 10, afbeelding 2 van 2
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
Conclusie
Aleah Ramos
533 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 236
