Ga door naar hoofdinhoud
Bissell Air180 Control Buttons Replacement
Aleah Ramos
Aleah Ramos en 2 andere bijdragers
Voor het laatst geüpdatet op December 19, 2022
5 minuten
Gemiddeld
The control buttons on the Bissell Air180 can be found along the top of the device on the same panel as the upper vent screen. These buttons can often malfunction, where one or more of them aren't working properly or they aren't properly responding to commands.
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Bissell Air180 Control Buttons Replacement, Air Filter: stap 1, afbeelding 1 van 2 Bissell Air180 Control Buttons Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Control Buttons Replacement: stap 2, afbeelding 1 van 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Control Buttons Replacement: stap 3, afbeelding 1 van 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Control Buttons Replacement, Power Supply: stap 4, afbeelding 1 van 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Control Buttons Replacement: stap 5, afbeelding 1 van 3 Bissell Air180 Control Buttons Replacement: stap 5, afbeelding 2 van 3 Bissell Air180 Control Buttons Replacement: stap 5, afbeelding 3 van 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Control Buttons Replacement, Control Buttons: stap 6, afbeelding 1 van 3 Bissell Air180 Control Buttons Replacement, Control Buttons: stap 6, afbeelding 2 van 3 Bissell Air180 Control Buttons Replacement, Control Buttons: stap 6, afbeelding 3 van 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Control Buttons Replacement: stap 7, afbeelding 1 van 2 Bissell Air180 Control Buttons Replacement: stap 7, afbeelding 2 van 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Control Buttons Replacement: stap 8, afbeelding 1 van 2 Bissell Air180 Control Buttons Replacement: stap 8, afbeelding 2 van 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
Conclusie
Aleah Ramos
533 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 96
