Asus X555LA-SI305041 Keyboard Assembly Replacement
Inleiding
Ga naar stap 1The keyboard assembly guide is an important guide for the rest of the guides for this device. You will need to reference this guide in order gain access to the inside of the laptop. This guide will also be useful if your keyboard or track pad have gone bad and need to be replaced.
Wat je nodig hebt
Gereedschap
Remove the following Phillips #0 screws from the lower case:
Six 9 mm screws
Four 11 mm screws
13 andere personen hebben deze handleiding voltooid.
