Ga door naar hoofdinhoud
Asus X553MA-BPD07051 Battery Replacement
Wat je nodig hebt
Video overzicht
  1. Asus X553MA-BPD07051 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Asus X553MA-BPD07051 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Battery Replacement: stap 2, afbeelding 1 van 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Battery Replacement: stap 3, afbeelding 1 van 2 Asus X553MA-BPD07051 Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
    The silver metal piece slides up (towards the monitor) to unlock the white plastic to lift up
    Wolphin - Antwoord
  5. Asus X553MA-BPD07051 Battery Replacement: stap 5, afbeelding 1 van 2 Asus X553MA-BPD07051 Battery Replacement: stap 5, afbeelding 2 van 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Battery Replacement: stap 6, afbeelding 1 van 2 Asus X553MA-BPD07051 Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up and remove it completely from the laptop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Stephanie DeCarvalho
949 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
3 Leden
2 opmerkingen
I used your guide when i repaired my mates X553. I found it quite easy. So thanks for the heads up on what to look out for :-)
gazza667 - Antwoord
Easy with the use of these clear instructions. Thanks and keep up the good work.
Marc Leclair - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 26
Altijd: 2,585
