Ga door naar hoofdinhoud
Asus X550ZA-SA100603E RAM Replacement
Paul Flynn
Paul Flynn en 5 andere bijdragers
Voor het laatst geüpdatet op January 10, 2025
25 - 45 minuten
Gemiddeld
This guide provides detailed step-by-step instructions to safely replace the RAM in the Asus Model X550ZA-SA100603E. If your laptop is lagging or running slowly, or if you wish to upgrade your RAM to boost performance, this guide may be helpful.
By following these steps, you can upgrade or replace the RAM and fix problems you may be experiencing with the memory.
Before you begin this repair, make sure to power off your laptop and unplug it from the charger. You should also backup your data before you start.
Wat je nodig hebt
Gereedschap
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them.
    • Seven 14 mm screws
    • Three 4 mm screws
    • Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: stap 2, afbeelding 1 van 1
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: stap 3, afbeelding 1 van 1
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
    • The flathead driver has the potential to damage the device. Be careful when handling it.
    • Do not be alarmed if you hear a click as you pry open. These sounds are the clips detaching from the casing.
  4. Asus X550ZA-SA100603E RAM Replacement: stap 4, afbeelding 1 van 2 Asus X550ZA-SA100603E RAM Replacement: stap 4, afbeelding 2 van 2
    • The motherboard is the big board on the left-hand side of the internals. Remove all 15 bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: stap 5, afbeelding 1 van 2 Asus X550ZA-SA100603E RAM Replacement: stap 5, afbeelding 2 van 2
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: stap 6, afbeelding 1 van 1
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot.
    • You will hear a clicking noise once it is pushed in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Flynn
16 Reputatie
2 handleidingen geschreven
IUPUI, Team S5-G5, Wilson Spring 2019 Lid van IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 412
