Asus X502C-RB01 Motherboard Replacement
Inleiding
Ga naar stap 1If your motherboard needs to be replaced or repaired, or need to get into other parts of the laptop, this guide will show you how to dismantle the motherboard.
Wat je nodig hebt
Turn off the laptop and flip it face down.
Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
With the same screwdriver, remove the four 5mm screws circled in orange.
Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
Unplug the bundled cable by pulling it away from the connector with a bit of force.
Unplug the display cable connector by lifting the tape and pulling it away from the connector.
Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
