Ga door naar hoofdinhoud
Asus X501A-RH31 Touch Pad Replacement
Christopher
Christopher en 3 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
30 minuten
Gemiddeld
This guide will demonstrate how to replace the touch pad in the Asus X501A-RH31 laptop. Please note, the touch pad is a sensitive piece of the laptop, execute caution when taking out the touch pad.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus X501A-RH31 Touch Pad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Touch Pad Replacement: stap 2, afbeelding 1 van 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Touch Pad Replacement: stap 3, afbeelding 1 van 2 Asus X501A-RH31 Touch Pad Replacement: stap 3, afbeelding 2 van 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Touch Pad Replacement, Keyboard: stap 4, afbeelding 1 van 2 Asus X501A-RH31 Touch Pad Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Touch Pad Replacement: stap 5, afbeelding 1 van 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Touch Pad Replacement: stap 6, afbeelding 1 van 2 Asus X501A-RH31 Touch Pad Replacement: stap 6, afbeelding 2 van 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Touch Pad Replacement: stap 7, afbeelding 1 van 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Touch Pad Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Touch Pad Replacement, Touch Pad: stap 9, afbeelding 1 van 2 Asus X501A-RH31 Touch Pad Replacement, Touch Pad: stap 9, afbeelding 2 van 2
    • Flip the keyboard over so the side without the keys is facing you.
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • The three screws are 2mm in length, 6.5mm in diameter.
  10. Asus X501A-RH31 Touch Pad Replacement: stap 10, afbeelding 1 van 2 Asus X501A-RH31 Touch Pad Replacement: stap 10, afbeelding 2 van 2
    • Detach the white data cable on the back of the touch pad.
    • Use tweezers to pull the white plastic piece up that is holding in the cable.
  11. Asus X501A-RH31 Touch Pad Replacement: stap 11, afbeelding 1 van 1
    • Peel the tan tape that holds the touch pad to the back of the keyboard.
    • Slide the touch pad up and out of the metal plate located near the bottom on the touch pad and keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher
371 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 577
