Asus X501A-RH31 Motherboard Replacement
Inleiding
Ga naar stap 1This guide will show how to remove and replace the motherboard. Please note the motherboard is a very fragile component of the laptop and can break easily.
Wat je nodig hebt
Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
