Ga door naar hoofdinhoud
Asus X401A Processor Replacement
Tyler Stiles
Tyler Stiles en 2 andere bijdragers
Voor het laatst geüpdatet op March 7, 2024
45 minuten - 1 uur
Gemiddeld
This guide will teach you how to take apart your laptop in order to get to the processor, fan, graphics card, and many other important components. Through the steps listed below, you will be able to identify and replace your laptop's processor!
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus X401A Processor Replacement, Processor: stap 1, afbeelding 1 van 2 Asus X401A Processor Replacement, Processor: stap 1, afbeelding 2 van 2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: stap 2, afbeelding 1 van 3 Asus X401A Processor Replacement: stap 2, afbeelding 2 van 3 Asus X401A Processor Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: stap 3, afbeelding 1 van 3 Asus X401A Processor Replacement: stap 3, afbeelding 2 van 3 Asus X401A Processor Replacement: stap 3, afbeelding 3 van 3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: stap 4, afbeelding 1 van 3 Asus X401A Processor Replacement: stap 4, afbeelding 2 van 3 Asus X401A Processor Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: stap 7, afbeelding 1 van 2 Asus X401A Processor Replacement: stap 7, afbeelding 2 van 2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: stap 9, afbeelding 1 van 3 Asus X401A Processor Replacement: stap 9, afbeelding 2 van 3 Asus X401A Processor Replacement: stap 9, afbeelding 3 van 3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: stap 10, afbeelding 1 van 2 Asus X401A Processor Replacement: stap 10, afbeelding 2 van 2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: stap 11, afbeelding 1 van 2 Asus X401A Processor Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: stap 12, afbeelding 1 van 3 Asus X401A Processor Replacement: stap 12, afbeelding 2 van 3 Asus X401A Processor Replacement: stap 12, afbeelding 3 van 3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Conclusie
Tyler Stiles
152 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-4, Wilder Spring 2017 Lid van Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Leden
5 handleidingen geschreven
Één opmerking
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,926
