Ga door naar hoofdinhoud
Asus X200MA Screen Replacement
Alli Krininger
Alli Krininger en 3 andere bijdragers
Voor het laatst geüpdatet op December 26, 2019
20 minuten - 1 uur
Gemiddeld
This guide provides step-by-step instructions on the replacement of the screen of ASUS X200MA. This guide can be used to replace a cracked or damaged screen casing or an improperly functioning screen. Use caution when removing stickers using the jimmy tool, as certain stickers are not meant to be removed, and will damage the screen in the event of their removal.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus X200MA Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Screen Replacement: stap 2, afbeelding 1 van 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Screen Replacement, Battery: stap 4, afbeelding 1 van 1
  5. Asus X200MA Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Screen Replacement: stap 6, afbeelding 1 van 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Screen Replacement: stap 8, afbeelding 1 van 1
    • Slide the battery up and out.
  9. Asus X200MA Screen Replacement, Screen: stap 9, afbeelding 1 van 1
    • Remove the following four 3 mm screws using the Phillips #0 screwdriver.
  10. Asus X200MA Screen Replacement: stap 10, afbeelding 1 van 2 Asus X200MA Screen Replacement: stap 10, afbeelding 2 van 2
    • Lift and separate the screen from the base plate.
  11. Asus X200MA Screen Replacement: stap 11, afbeelding 1 van 2 Asus X200MA Screen Replacement: stap 11, afbeelding 2 van 2
    • Insert the metal spudger into the side of the screen casing. Work the spudger around the perimeter of the casing in a rowing motion in order to release the plastic clips holding the casing together.
    • Place a finger in the space between the casing while undoing the clips to keep the casing from re-closing.
  12. Asus X200MA Screen Replacement: stap 12, afbeelding 1 van 1
    • Lift the half of the casing with the screen away from the other half of the casing and place the screen half on a work space by itself.
  13. Asus X200MA Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the following six 3 mm screws using the Phillips #0 screwdriver.
  14. Asus X200MA Screen Replacement: stap 14, afbeelding 1 van 3 Asus X200MA Screen Replacement: stap 14, afbeelding 2 van 3 Asus X200MA Screen Replacement: stap 14, afbeelding 3 van 3
    • Use the jimmy tool to peel the following stickers from the screen:
    • The silver sticker near the bottom.
    • The information sticker near the top.
  15. Asus X200MA Screen Replacement: stap 15, afbeelding 1 van 3 Asus X200MA Screen Replacement: stap 15, afbeelding 2 van 3 Asus X200MA Screen Replacement: stap 15, afbeelding 3 van 3
    • Lift the latch holding the component in place.
    • Remove the component by pulling in the direction of the arrows.
  16. Asus X200MA Screen Replacement: stap 16, afbeelding 1 van 2 Asus X200MA Screen Replacement: stap 16, afbeelding 2 van 2
    • Lift the screen from the casing and place the two next to one another.
Conclusie
Alli Krininger
391 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G4, Stella Fall 2019 Lid van IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 865
