Ga door naar hoofdinhoud
Asus X200CA-HCL 1104G Headphone Jack Replacement
Samantha Wahl
Samantha Wahl en 2 andere bijdragers
Voor het laatst geüpdatet op December 31, 2017
Geen schatting
Eenvoudig
Betere introductie
Wat je nodig hebt
Gereedschap
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Asus X200CA-HCL 1104G Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Conclusie
Samantha Wahl
301 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 141
