Ga door naar hoofdinhoud
Asus ROG G20CB Graphics Card Replacement
Wat je nodig hebt
  1. Asus ROG G20CB Graphics Card Replacement, Fan: stap 1, afbeelding 1 van 2 Asus ROG G20CB Graphics Card Replacement, Fan: stap 1, afbeelding 2 van 2
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus ROG G20CB Graphics Card Replacement: stap 2, afbeelding 1 van 1
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus ROG G20CB Graphics Card Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus ROG G20CB Graphics Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus ROG G20CB Graphics Card Replacement: stap 5, afbeelding 1 van 1
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus ROG G20CB Graphics Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus ROG G20CB Graphics Card Replacement, Graphics Card: stap 7, afbeelding 1 van 1
    • Remove the three 4.6 mm Phillips screws from the graphics card housing.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus ROG G20CB Graphics Card Replacement: stap 8, afbeelding 1 van 1
    • Pull the graphics card housing out of the case.
    • Be mindful of the 8-pin power cable connected to the graphics card.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus ROG G20CB Graphics Card Replacement: stap 9, afbeelding 1 van 1
    • Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus ROG G20CB Graphics Card Replacement: stap 10, afbeelding 1 van 1
    • Remove the 3.7 mm Phillips screw from the graphics card and its housing.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus ROG G20CB Graphics Card Replacement: stap 11, afbeelding 1 van 1
    • Slide the graphics card out of the housing.
    Vraag FixBot
    Voeg opmerking toe
  12. Asus ROG G20CB Graphics Card Replacement: stap 12, afbeelding 1 van 1
    • Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
    • This riser will need to be used with the new graphics card in order to be installed in this system.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
AdamGadd
349 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-3, Botvin Spring 2025 Lid van UMass Dartmouth, Team 3-3, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G3
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 68
Altijd: 619
