Ga door naar hoofdinhoud
Asus ROG Ally Battery Disconnect
Spencer Day
Spencer Day en 2 andere bijdragers
Voor het laatst geüpdatet op November 20, 2024
Geen schatting
Gemiddeld
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
This guide demonstrates how to disconnect the battery in your Asus ROG Ally. This should be done before all major repairs.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus ROG Ally Battery Disconnect, Unfasten the back cover: stap 1, afbeelding 1 van 2 Asus ROG Ally Battery Disconnect, Unfasten the back cover: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  2. Asus ROG Ally Battery Disconnect, Insert an opening pick: stap 2, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Insert an opening pick: stap 2, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Insert an opening pick: stap 2, afbeelding 3 van 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  3. Asus ROG Ally Battery Disconnect, Release the back cover's clips: stap 3, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Release the back cover's clips: stap 3, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Release the back cover's clips: stap 3, afbeelding 3 van 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  4. Asus ROG Ally Battery Disconnect, Remove the back cover: stap 4, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Remove the back cover: stap 4, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Remove the back cover: stap 4, afbeelding 3 van 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  5. Asus ROG Ally Battery Disconnect, Remove the plastic cover: stap 5, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Remove the plastic cover: stap 5, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Remove the plastic cover: stap 5, afbeelding 3 van 3
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  6. Asus ROG Ally Battery Disconnect, Unlatch the locking bar: stap 6, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Unlatch the locking bar: stap 6, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Unlatch the locking bar: stap 6, afbeelding 3 van 3
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  7. Asus ROG Ally Battery Disconnect, Disconnect the battery: stap 7, afbeelding 1 van 3 Asus ROG Ally Battery Disconnect, Disconnect the battery: stap 7, afbeelding 2 van 3 Asus ROG Ally Battery Disconnect, Disconnect the battery: stap 7, afbeelding 3 van 3
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
Conclusie
Spencer Day
95.715 Reputatie
662 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.545 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 33
