Ga door naar hoofdinhoud
Asus Q525U Battery Replacement
Wat je nodig hebt
    1. Asus Q525U Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Asus Q525U Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Asus Q525U Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Begin by powering off the device and flipping the device over.
      • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
      • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus Q525U Battery Replacement: stap 2, afbeelding 1 van 3 Asus Q525U Battery Replacement: stap 2, afbeelding 2 van 3 Asus Q525U Battery Replacement: stap 2, afbeelding 3 van 3
      • Use an opening pick to separate the back cover from the device.
      • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus Q525U Battery Replacement: stap 3, afbeelding 1 van 3 Asus Q525U Battery Replacement: stap 3, afbeelding 2 van 3 Asus Q525U Battery Replacement: stap 3, afbeelding 3 van 3
      • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
      • The back cover should be easily removable, allowing full access to all of the internal components.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus Q525U Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Asus Q525U Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Asus Q525U Battery Replacement, Battery: stap 4, afbeelding 3 van 3
      • The battery of the device is outlined in red.
      • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus Q525U Battery Replacement: stap 5, afbeelding 1 van 2 Asus Q525U Battery Replacement: stap 5, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      Halberd Spudger
      $2.99
      • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Asus Q525U Battery Replacement: stap 6, afbeelding 1 van 1
      • Lift the battery out of the frame to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Will Targonski
153 Reputatie
1 Handleiding geschreven
Clemson, Team 2-5, Hunter Spring 2022 Lid van Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 53
Altijd: 2,006
