Ga door naar hoofdinhoud
Asus Q500A RAM Replacement
cameron
cameron en 10 andere bijdragers
Voor het laatst geüpdatet op January 3, 2024
10 - 25 minuten
Gemiddeld
Actiemomenten
Onjuiste gereedschappen
Heeft betere plaatjes nodig
If the device crashes while doing multiple tasks simultaneously, it is possibly due to insufficient amounts of ram. Replacing your ram will improve your computer's performance. This guide will properly demonstrate how to replace the RAM in the Asus Q500A laptop effectively.
Wat je nodig hebt
Gereedschap
  1. Asus Q500A RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Asus Q500A RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Flip device upside-down.
    • Remove back-plate by unscrewing the two screws on either side of the back-plate.
    • Remove the plastic cover.
  2. Asus Q500A RAM Replacement: stap 2, afbeelding 1 van 1
    • Depending on the model of the device, there will either be one or two sticks of ram.
    • There are two metal brackets holding each ram stick in.
    • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
  3. Asus Q500A RAM Replacement: stap 3, afbeelding 1 van 2 Asus Q500A RAM Replacement: stap 3, afbeelding 2 van 2
    • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
  4. Asus Q500A RAM Replacement: stap 4, afbeelding 1 van 1
    • To insert the ram line up the ram stick and the slot.
    • Next you will have to push the ram down until it snaps into place.
    • Be careful not to do this too hard, as it can break the ram.
    • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
Conclusie
cameron
319 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-5, Eyestone Spring 2017 Lid van USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 775
