Asus Q200E-CT144H Wi-Fi Card Replacement
Inleiding
Ga naar stap 1The Wi-Fi Card is responsible for transmitting data the same way a cell phone or radio does, through radio waves. Your Wi-Fi Card should be able to pick up a signal from the nearby radios using its tiny antennas. If you are having problems with connecting to the internet using your Wi-Fi Card also known as the Local Area Network Card (LAN), you can use this guide to replace your Wi-Fi Card.
Wat je nodig hebt
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the battery connector by using tweezers to lift up on it.
Use tweezers or your fingers to disconnect the Wi-Fi card's power connector.
