Ga door naar hoofdinhoud
Asus Chromebook Flip C100P Battery Replacement
Ruofan Wang
Ruofan Wang en 9 andere bijdragers
Voor het laatst geüpdatet op April 27, 2020
1 uur
Gemiddeld
These steps will help you in the replacement of the battery for an Asus Chromebook Flip C100P. Either the battery has lost its ability to hold a charge, which in turn means you most likely have a dead battery that needs to be replaced. Before beginning, make sure to power off your device completely and disconnect the device from any external power source. '''A punctured battery can cause a dangerous fire. If your battery is swollen, take the appropriate precautions in this link: ++What to do with a swollen battery '''
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100P Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100P Battery Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100P Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100P Battery Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Disconnect the two cables from the motherboard with tweezers
  6. Asus Chromebook Flip C100P Battery Replacement, Battery: stap 6, afbeelding 1 van 1
    • Unscrew the four J1 Screws of the Audio Cards
  7. Asus Chromebook Flip C100P Battery Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
  8. Asus Chromebook Flip C100P Battery Replacement: stap 8, afbeelding 1 van 1
    • Lift the battery cable out of Mother Board
Conclusie
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
12 andere personen hebben deze handleiding voltooid.
Ruofan Wang
191 Reputatie
1 Handleiding geschreven
2 opmerkingen
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
Chas Hofmeister - Antwoord
I had to searched high and low for this but I'm glad I found this site. Thanks for a great how-to, well done. I wish other sites were a clear and concise.
Eugene Carroll - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 43
Altijd: 11,617
