Ga door naar hoofdinhoud
Astak Mole Microphone  Replacement
Joseph Bello
Joseph Bello en 6 andere bijdragers
Voor het laatst geüpdatet op February 27, 2021
Geen schatting
Gemiddeld
Onjuiste gereedschappen
Knip- en plakwerk
If you are experiencing microphone problems, you may have to repair or replace the microphone. Before this can be accomplished, you must access the motherboard. This guide will show you how to do this.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Astak Mole Microphone  Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Microphone  Replacement: stap 2, afbeelding 1 van 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Microphone  Replacement: stap 3, afbeelding 1 van 1
    • Remove the SD card.
  4. Astak Mole Microphone  Replacement: stap 4, afbeelding 1 van 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Microphone  Replacement: stap 5, afbeelding 1 van 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Microphone  Replacement, Microphone: stap 6, afbeelding 1 van 1
    • Remove microphone from its holder on the bottom section of the casing.
  7. Astak Mole Microphone  Replacement: stap 7, afbeelding 1 van 1
    • Access microphone and assess damage.
  8. Astak Mole Microphone  Replacement: stap 8, afbeelding 1 van 1
    • Remove microphone input with metal spudger. Be sure to sever electrical adhesive in order to separate input and output.
    • It is advised to re-apply adhesive to the cable once the new microphone cable is replaced.
Conclusie
Joseph Bello
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2016 Lid van USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 225
