Ga door naar hoofdinhoud
Arlo Pro 2 Camera Micro-USB Port Replacement
Wat je nodig hebt
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: stap 1, afbeelding 1 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: stap 1, afbeelding 2 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: stap 1, afbeelding 3 van 3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: stap 2, afbeelding 1 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 2, afbeelding 2 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 2, afbeelding 3 van 3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Arlo Pro 2 Camera Micro-USB Port Replacement: stap 3, afbeelding 1 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 3, afbeelding 2 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 3, afbeelding 3 van 3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Arlo Pro 2 Camera Micro-USB Port Replacement: stap 4, afbeelding 1 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 4, afbeelding 2 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 4, afbeelding 3 van 3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      Vraag FixBot
      Voeg opmerking toe
    5. Arlo Pro 2 Camera Micro-USB Port Replacement: stap 5, afbeelding 1 van 2 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 5, afbeelding 2 van 2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      Vraag FixBot
      Voeg opmerking toe
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: stap 6, afbeelding 1 van 2 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: stap 6, afbeelding 2 van 2
      • Thread the wires of the Micro-USB port through the casing.
      • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: stap 7, afbeelding 1 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 7, afbeelding 2 van 3 Arlo Pro 2 Camera Micro-USB Port Replacement: stap 7, afbeelding 3 van 3
      • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
      • Gently remove the Micro-USB port by pulling it away from the case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-2, Botvin Spring 2025 Lid van UMass Dartmouth, Team 2-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S2G2
3 Leden
27 handleidingen geschreven
1Gids Commentaar
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 58
Altijd: 414
