Ga door naar hoofdinhoud
Apple Powerbook 5300 Battery Replacement
Alex Wineteer
Alex Wineteer en 14 andere bijdragers
Voor het laatst geüpdatet op December 2, 2024
1 minuut
Zeer eenvoudig
Actiemomenten
Betere introductie
This guide will show you how to install a Powerbook 5300 battery.
  1. Apple Powerbook 5300 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Apple Powerbook 5300 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Wineteer
154 Reputatie
1 Handleiding geschreven
Cal Poly, Team 25-30, Garner Spring 2011 Lid van Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 3,141
