Inleiding
This guide will help you replace the Anker Soundcore Motion Boom Plus tweeters. The tweeters are the smaller speakers on the side of the device designed to reproduce high-frequency sounds. If your device is experiencing distorted or crackling sounds, the tweeters may be damaged and require replacement. Be sure to turn off the device before taking it apart and use the tools recommended to avoid any damage to the device.
Wat je nodig hebt
Insert an opening tool into the seam between the speaker grille and the chassis.
Pry the tool around the top, bottom, and sides until the grille fully releases.
Remove the grille.
Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
