Ga door naar hoofdinhoud
Anker Soundcore Motion 300 Drivers Replacement
Wat je nodig hebt
  1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: stap 1, afbeelding 1 van 2 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: stap 1, afbeelding 2 van 2
    • Insert an opening tool into a seam between the grille and chassis.
    • Gently pry the grille up to begin disengaging the retaining clip.
    • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    Vraag FixBot
    Voeg opmerking toe
  2. Anker Soundcore Motion 300 Drivers Replacement: stap 2, afbeelding 1 van 2 Anker Soundcore Motion 300 Drivers Replacement: stap 2, afbeelding 2 van 2
    • Keep working around the edges until all the clips are loose.
    • You may hear soft clicking sounds as the clips come undone.
    Vraag FixBot
    Voeg opmerking toe
  3. Anker Soundcore Motion 300 Drivers Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the grille from the speaker.
    Vraag FixBot
    Voeg opmerking toe
  4. Anker Soundcore Motion 300 Drivers Replacement, Drivers: stap 4, afbeelding 1 van 3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: stap 4, afbeelding 2 van 3 Anker Soundcore Motion 300 Drivers Replacement, Drivers: stap 4, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    Vraag FixBot
    Voeg opmerking toe
  5. Anker Soundcore Motion 300 Drivers Replacement: stap 5, afbeelding 1 van 3 Anker Soundcore Motion 300 Drivers Replacement: stap 5, afbeelding 2 van 3 Anker Soundcore Motion 300 Drivers Replacement: stap 5, afbeelding 3 van 3
    • Use an opening tool to pry up the speaker housing.
    • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
    • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  6. Anker Soundcore Motion 300 Drivers Replacement: stap 6, afbeelding 1 van 3 Anker Soundcore Motion 300 Drivers Replacement: stap 6, afbeelding 2 van 3 Anker Soundcore Motion 300 Drivers Replacement: stap 6, afbeelding 3 van 3
    • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
    • Repeat the previous bullet for the other driver.
    • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
    • Disconnect each of the the two driver connectors from the motherboard.
    • There may be a small piece of sealant that must be removed before the connectors can be removed.
    • Remove the drivers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Holly Hoffman
487 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 61
Altijd: 613
