Ga door naar hoofdinhoud
Anker SoundCore 2 Bluetooth Chip Replacement
Wat je nodig hebt
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: stap 1, afbeelding 2 van 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Vraag FixBot
      Voeg opmerking toe
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 3 van 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      Vraag FixBot
      Voeg opmerking toe
    2. Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 3 van 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: stap 4, afbeelding 1 van 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: stap 4, afbeelding 2 van 2
      • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
      • For help desoldering and soldering, follow this guide.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
1Gids Commentaar
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 63
Altijd: 3,011
