Ga door naar hoofdinhoud
Anker SoundCore 2 Battery Replacement
Wat je nodig hebt
    1. Anker SoundCore 2 Battery Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement, Front Panel: stap 1, afbeelding 2 van 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Vraag FixBot
      Voeg opmerking toe
    1. Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Be careful not to damage the rubber gasket around the speaker mount plate.
      • Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
      Vraag FixBot
      Voeg opmerking toe
    2. Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 3 van 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #1 screwdriver. Some variants have 2 screws.
      • Carefully remove the bluetooth antenna wire from the left of the board. It pulls up without much pressure.
      • Flip up the motherboard to expose the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Anker SoundCore 2 Battery Replacement: stap 4, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement: stap 4, afbeelding 2 van 2
      • Use a nylon spudger to remove the battery from the speaker casing.
      • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
      • The battery is glued down so it may be difficult to remove.
      Vraag FixBot
      Voeg opmerking toe
    4. Anker SoundCore 2 Battery Replacement: stap 5, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement: stap 5, afbeelding 2 van 2
      • Unplug the wire that connects the battery with the motherboard.
      • Battery specs: 2 x 18650 2600mAh soldered in series (to bring voltage to 7.4V).
      • Can safely be upgraded to 2 x 18650 3500mAh for additional capacity.
      • When replacing the battery, plug in the new battery where the old one was plugged in.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
8Gids Commentaar
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - Antwoord Deel
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - Antwoord Deel
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - Antwoord Deel
Akku SoundCore2
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
Andreas Reheis - Antwoord Deel
same. i tried cleaning and drying, even an improvised other battery but nothing happens. charging only ever shows red light.
JohnLS17 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 116
Afgelopen 30 dagen: 630
Altijd: 25,343
