Ga door naar hoofdinhoud
Anbernic RG353V Screen Replacement
Wat je nodig hebt
  1. Anbernic RG353V Screen Replacement, Circuit Board: stap 1, afbeelding 1 van 3 Anbernic RG353V Screen Replacement, Circuit Board: stap 1, afbeelding 2 van 3 Anbernic RG353V Screen Replacement, Circuit Board: stap 1, afbeelding 3 van 3
    • Make sure to remove the SD cards from the device before repair. Push them inwards so that they pop out of their respective slots.
    • Use a 2 mm Hex screwdriver to remove the six 7 mm screws from the back case of the handheld game.
    • Use an opening tool to pry the top and bottom of the game apart. Work the tool around the perimeter of the device between the seam to release the snap tabs.
    • Separate the top and bottom cases gently.
    • Don't pull them apart as they are connected by cables and pulling them could rip the wires and damage the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Anbernic RG353V Screen Replacement: stap 2, afbeelding 1 van 3 Anbernic RG353V Screen Replacement: stap 2, afbeelding 2 van 3 Anbernic RG353V Screen Replacement: stap 2, afbeelding 3 van 3
    • Push on alternating sides of the connector to disconnect the battery wire from the main circuit board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • To disconnect the cable coaxial cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
    • Disconnecting these wires will allow you to separate the back of the case from the front in order to work more freely.
    Vraag FixBot
    Voeg opmerking toe
  3. Anbernic RG353V Screen Replacement: stap 3, afbeelding 1 van 2 Anbernic RG353V Screen Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the five 7 mm Phillips from the plate covering the bottom of the circuit board.
    • Remove the black cover.
    • The next three steps after this one can be done in any order.
    Vraag FixBot
    Voeg opmerking toe
  4. Anbernic RG353V Screen Replacement: stap 4, afbeelding 1 van 2 Anbernic RG353V Screen Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 to remove the four 6 mm screws attaching the thumbsticks to the circuit board.
    • Use a spudger to flip up the locking flaps of the ZIF connectors.
    • Use tweezers or your fingers to gently pull the red ribbon cables out of their sockets.
    Vraag FixBot
    Voeg opmerking toe
  5. Anbernic RG353V Screen Replacement: stap 5, afbeelding 1 van 3 Anbernic RG353V Screen Replacement: stap 5, afbeelding 2 van 3 Anbernic RG353V Screen Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to flip up the locking flap of the ZIF connector.
    • Use tweezers or your fingers to gently pull the bronze-colored ribbon cable out of its socket.
    • Use tweezers or your fingers to remove the small black ribbon cable from the socket.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    Vraag FixBot
    Voeg opmerking toe
  6. Anbernic RG353V Screen Replacement: stap 6, afbeelding 1 van 2 Anbernic RG353V Screen Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws that secure the circuit board to the case.
    Vraag FixBot
    Voeg opmerking toe
  7. Anbernic RG353V Screen Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the circuit board by pulling it upward and away from the case.
    • Gently thread the two ribbon cables through the slot to avoid damage.
    Vraag FixBot
    Voeg opmerking toe
  8. Anbernic RG353V Screen Replacement, Screen: stap 8, afbeelding 1 van 2 Anbernic RG353V Screen Replacement, Screen: stap 8, afbeelding 2 van 2
    • Remove the black tape at the top of the device.
    • Make sure to keep this as you will need to put it back on later.
    • Insert the iFixit opening tool in between the case frame and the metal screen plate to separate the adhesive from each side.
    • Take your time with this step to avoid damaging the device, as the adhesive is very strong.
    Vraag FixBot
    Voeg opmerking toe
  9. Anbernic RG353V Screen Replacement: stap 9, afbeelding 1 van 3 Anbernic RG353V Screen Replacement: stap 9, afbeelding 2 van 3 Anbernic RG353V Screen Replacement: stap 9, afbeelding 3 van 3
    • Press the metal plate from behind with your thumb to gently push the screen out.
    • The ribbon cables will come out along with it.
    • If the adhesive was not released sufficiently in the previous step, you may need to go back with a spudger and pry along the area to loosen the connection.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Konnor
712 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 93
Altijd: 1,907
