Analogue Pocket Battery Shell Replacement
Inleiding
Ga naar stap 1Use this guide to remove or replace the battery shell (AKA battery cover, rear cover) on your Analogue pocket.
Wat je nodig hebt
Gereedschap
Unplug all cables and fully power off your device.
Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
Lift the bottom edge of the battery shell to unhook its tabs.
Remove the battery shell.
