Ga door naar hoofdinhoud
Amazon Fire Max 11 LCD Touch Screen Replacement
Wat je nodig hebt
    1. Amazon Fire Max 11 LCD Touch Screen Replacement, LCD Touch Screen: stap 1, afbeelding 1 van 1
      • The heat gun can get very hot and can burn skin. If the device is heated for too long, it can be damaged.
      • Use a heat gun along the edges of the screen to loosen the adhesive.
      • Insert the iFixit opening tool along the seam between the screen and back case and gently pry around the perimeter of the screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire Max 11 LCD Touch Screen Replacement: stap 2, afbeelding 1 van 2 Amazon Fire Max 11 LCD Touch Screen Replacement: stap 2, afbeelding 2 van 2
      • Once the screen has been separated from the case, lift it slightly to reveal the display cable connected to the motherboard.
      • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
      • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
      • To reconnect:
      • Grip the cable and buckle together and insert the connector fully into its socket.
      • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
      • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
      • Remove the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Anthony Martins
522 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-3, Konn Spring 2024 Lid van UMass Dartmouth, Team 1-3, Konn Spring 2024
UMASSD-KONN-S24S1G3
4 Leden
4Gids Commentaar
Okay, so I just replaced my screen and when powering back up the screen is black. I can hear the tone when it turns on or off, not sure which one because the screen is blank. Is the new lcd screen bad.
Carl Lee Fuller - Antwoord Deel
I went in and re-sat the ribbon and now I the lcd works but the touch screen does not work.
Followed the guide, got the screen replaced, everything works, good guide! A couple notes. My tablet had a piece of tape holding the wire in, I had to remove that, which is easy, but wasn't mentioned. Second, when you go to unplug the cable, the connector unclips from the opposite side to where the cable plugs in. So holding your tool at the edge of the screen go to the side of the connector closest to the edge and flip it up. Also, because someone else had a similar issue, I made sure the screen worked before I put the tablet back together which was good because I had an issue where the screen turned on but stayed black as well as the screen turned on but the touch part wasn't working. Reseating the cable worked. Third time was the charm. Power on open electronics at your own risk.
TLDR:
It is a VERY finicky cable.
Nicholas H - Antwoord Deel
Any Idea were I can source the frame of this tablet
Emily Cameron - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 89
Altijd: 2,602
