Ga door naar hoofdinhoud
Alienware Pro Wireless Gaming Mouse Battery Replacement
Wat je nodig hebt
  1. Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: stap 1, afbeelding 1 van 3 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: stap 1, afbeelding 2 van 3 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: stap 1, afbeelding 3 van 3
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 2, afbeelding 1 van 2 Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 2, afbeelding 2 van 2
    • Peel and remove the other mouse foot.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware Pro Wireless Gaming Mouse Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 4, afbeelding 1 van 3 Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 4, afbeelding 2 van 3 Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 4, afbeelding 3 van 3
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 5, afbeelding 1 van 2 Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 5, afbeelding 2 van 2
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
    Vraag FixBot
    Voeg opmerking toe
  6. Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 6, afbeelding 1 van 2 Alienware Pro Wireless Gaming Mouse Battery Replacement: stap 6, afbeelding 2 van 2
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Matt Seay
401 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 264
