Ga door naar hoofdinhoud
Adjusting the Weight of a Logitech G502 Hero
Joseph Ambrico
Joseph Ambrico en 5 andere bijdragers
Voor het laatst geüpdatet op February 16, 2024
5 minuten
Zeer eenvoudig
Heeft betere plaatjes nodig
If you are experiencing a 'weightless' Logitech G502 Hero, and would like to increase weight of the mouse for better usage, use this guide to properly adjust the weight on your Logitech G502 Hero.
Before using this guide, insure all original packaging equipment is located. To add this weight, the original packaging will provide the mentioned weights.
If you are interested in removing any weights, you must follow the guide in reverse order, unplugging the mouse being the first step.
  1. Adjusting the Weight of a Logitech G502 Hero, Adjusting the Weight of a Logitech G502 Hero: stap 1, afbeelding 1 van 1
    • Unplug the mouse from your computer
  2. Adjusting the Weight of a Logitech G502 Hero: stap 2, afbeelding 1 van 1
    • Turn the mouse so that the bottom of the mouse is upright.
  3. Adjusting the Weight of a Logitech G502 Hero: stap 3, afbeelding 1 van 2 Adjusting the Weight of a Logitech G502 Hero: stap 3, afbeelding 2 van 2
    • Use your fingers to lift the magnetic backplate away from the mouse.
  4. Adjusting the Weight of a Logitech G502 Hero: stap 4, afbeelding 1 van 2 Adjusting the Weight of a Logitech G502 Hero: stap 4, afbeelding 2 van 2
    • A set of weights are included with the device in a small black box.
    • Adjust the weights by putting in as many weights as you desire.
    • Each one weighs 3.6g. If you're not sure where to place the weights, use the second picture as a guide.
  5. Adjusting the Weight of a Logitech G502 Hero: stap 5, afbeelding 1 van 2 Adjusting the Weight of a Logitech G502 Hero: stap 5, afbeelding 2 van 2
    • Snap the magnetic plate back in the mouse.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joseph Ambrico
177 Reputatie
1 Handleiding geschreven
Één opmerking
I feel that putting a piece on the top-left corner (where the cover olds place) and in the very bottom or second to last position gives the mouse a more balanced feel
caramelo94 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 173
Altijd: 7,906
