Ga door naar hoofdinhoud
Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement
Lauryn F
Lauryn F en 3 andere bijdragers
Voor het laatst geüpdatet op January 13, 2025
15 - 20 minuten
Gemiddeld
Uitgelichte studenten-handleiding
The motherboard is the main circuit board of the Acer Chromebook (Spin 511 (C741L) N20Q8), providing power to each part of the laptop in order to communicate and turn on. With a faulty motherboard, the Chromebook may shut down randomly or not even power on. If this happens, a replacement of the motherboard is needed in order for the device to work again.
Make sure to power down your device and disconnect from any power sources before you begin.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: stap 3, afbeelding 2 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: stap 3, afbeelding 3 van 3
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
    • Flip the gray hinges up.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the two metal plates that were previously held down by each hinge.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Detach the connector from the motherboard.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the blue, yellow, and black wires from their connectors.
  8. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the tape from the black connector and gently remove it from the socket.
  9. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 9, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Carefully remove the pin connector containing the black, white, and red wires from its socket.
  10. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 10, afbeelding 1 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 10, afbeelding 2 van 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Detach the long connector from the socket.
    • Remove the motherboard from the device.
Conclusie
Lauryn F
710 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 100
