Ga door naar hoofdinhoud
Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement
Lauryn F
Lauryn F en 2 andere bijdragers
Voor het laatst geüpdatet op January 6, 2025
15 - 30 minuten
Gemiddeld
If your Acer Chromebook (Spin 511 C741L N20Q8) screen is turning off, has dead pixels, or will not display anything, the screen may be broken or defective. In order to display images again, the display assembly may need to be replaced.
Before beginning, ensure that the device is powered off and disconnected from any external sources. Then, follow these steps to replace your display assembly.
Wat je nodig hebt
Gereedschap
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Display Assembly: stap 3, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Display Assembly: stap 3, afbeelding 2 van 2
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Flip up the hinges on each side that were previously secured down by the screws.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 5, afbeelding 2 van 2
    • Carefully detach the blue, yellow, and black wires from their connectors.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove the electrical tape from the black connector and gently remove it from the socket.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • The base and display assembly are now able to be separated. Simply pull and remove the display assembly from the base of the laptop.
Conclusie
Lauryn F
710 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 20
Altijd: 77
