Ga door naar hoofdinhoud
Acer Aspire V5-591G-75KE Memory Modules Replacement
Reina Godeck
Reina Godeck en 2 andere bijdragers
Voor het laatst geüpdatet op April 19, 2022
5 - 10 minuten
Gemiddeld
This guide will help you identify, remove, and potentially replace the memory modules within the Acer Aspire V5-591G-75KE.
Acer Aspire V5-591G-75KE is manufactured with two DDR4 SDRAM memory card slots with a standard capacity of 16 GB and a maximum of 32 GB.
Wat je nodig hebt
Onderdelen
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 1 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 2 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 3 van 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 2, afbeelding 1 van 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 2, afbeelding 2 van 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 3, afbeelding 1 van 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 3, afbeelding 2 van 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 4, afbeelding 1 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 4, afbeelding 2 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: stap 5, afbeelding 1 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: stap 5, afbeelding 2 van 3 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: stap 5, afbeelding 3 van 3
    • Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
    • Using both hands, pull the clasps away simultaneously in order to release the memory modules.
    • Once the clasps have been released, each memory module will spring up.
  6. Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V5-591G-75KE Memory Modules Replacement: stap 6, afbeelding 2 van 2
    • To remove the top memory module, lift the module slightly up and pull away.
    • Repeat the previous step to remove the bottom memory module.
    • Take note of the pins on the bottom of each memory module and make sure they line up with the slots when re-installing the memory modules. Once aligned and inserted, simply push the memory module down to lock it in place.
Conclusie
Reina Godeck
741 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S3-G5, Liner Fall 2017 Lid van UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Leden
18 handleidingen geschreven
Één opmerking
Great job on the guide! looks very professional!
Aiden - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 522
