Acer Aspire V5-591G-75KE Fan and Heatsink Replacement
Inleiding
Ga naar stap 1This guide will show the user how to remove the fan and heat-sink.
Do not proceed with this guide unless you are prepared to clean and re-apply thermal compound. For more information, please refer to the How to Clean and Apply Thermal Compound guide.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
Use a pair of blunt tweezers to gently push on the 3-pin connector. This disconnects the fan from the motherboard.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
Één andere persoon heeft deze handleiding voltooid.
