Ga door naar hoofdinhoud
Acer Aspire V5-572, V5-572G Battery Replacement
ZFix
ZFix en 4 andere bijdragers
Voor het laatst geüpdatet op April 19, 2022
20 minuten
Eenvoudig
Door de gemeenschap gemaakte handleiding
How to disassemble Acer Aspire - V5-572, V5-572G and replace the old Battery.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
Video overzicht
  1. Acer Aspire V5-572, V5-572G Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Battery Replacement: stap 2, afbeelding 1 van 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Battery Replacement: stap 3, afbeelding 1 van 3 Acer Aspire V5-572, V5-572G Battery Replacement: stap 3, afbeelding 2 van 3 Acer Aspire V5-572, V5-572G Battery Replacement: stap 3, afbeelding 3 van 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Antwoord
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Antwoord
  4. Acer Aspire V5-572, V5-572G Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery
    How much will cost me a replacement battery?
    Anthony Borg - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
194.093 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
Één opmerking
I plugged a wrong charger on my acer aspire v5 15-572 now it dosent charge what could be the problem
Joseph Musariri - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 15,877
