Ga door naar hoofdinhoud
Acer Aspire V5-571P-6815 Keyboard  Replacement
Jmarqu2
Jmarqu2 en 3 andere bijdragers
Voor het laatst geüpdatet op April 18, 2022
3 minuten
Eenvoudig
This guide will show how to replace the keyboard on a Acer Aspire V5-571P-6815 laptop.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Acer Aspire V5-571P-6815 Keyboard  Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  2. Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 2, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 2, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  3. Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 3, afbeelding 1 van 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 3, afbeelding 2 van 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
Conclusie
Jmarqu2
133 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G4, Liner Spring 2018 Lid van UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Leden
8 handleidingen geschreven
2 opmerkingen
This guide is wrong. All keyboard sold online come without the frame and replacing the keyboard is actually a very tedious process as it’s attached with melt plastic.
Sergey Ratakhin - Antwoord
Thank you! All this guide shows is how to take out and put in the exact same keyboard, which doesn't seem to be available anywhere. I've been looking for an exact replacement and haven't been able to find one. The original keyboard has the frame with the power button. NONE of the replacement options has ANYTHING with the power button.
Raul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 3,430
