Ga door naar hoofdinhoud
Acer Aspire V5-131-2680 Screen Replacement
Mauricio Moreno
Mauricio Moreno en 3 andere bijdragers
Voor het laatst geüpdatet op December 28, 2022
5 minuten
Gemiddeld
If you need to replace the screen of your Acer Aspire V5, you have come to the right place!
If your laptop does not display anything or is very dark, consider these options first. Your monitor, and not your screen, might be faulty, or you might have an outdated graphic driver. Try troubleshooting your laptop first to see if you have any of these internal problems before replacing you screen.
If you want to replace your screen because it is physically scratched, cracked, or damaged, continue with the replacement guide! You will need an opening tool, a precision bit driver, a Phillips/JIS J1 and, a magnetic pickup bit.
Before beginning, make sure to close, power off your laptop completely, and disconnect from any external power source.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: stap 2, afbeelding 1 van 1
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: stap 4, afbeelding 1 van 1
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: stap 5, afbeelding 1 van 1
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
Conclusie
Mauricio Moreno
601 Reputatie
5 handleidingen geschreven
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 151
