Ga door naar hoofdinhoud
Acer Aspire V5-131-2680 Motherboard Replacement
Mauricio Moreno
Mauricio Moreno en 6 andere bijdragers
Voor het laatst geüpdatet op January 5, 2024
8 minuten
Gemiddeld
Behoeft meer afbeeldingen
Ontbrekende stappen
If you want to upgrade or replace a broken motherboard for your Acer Aspire V5, then this guide will help you do that. Common issues of a damaged motherboard are constant error messages, constant freezing, USB ports not working with devices plugged into them, and the Acer Aspire V5 shutting down or not booting up properly. If you have these issues, then it's best to replace your motherboard so your other components don't get damaged.
You will need an opening tool, a precision bit driver, and a magnetic pickup bit.
Before beginning, make sure to close, power off your laptop completely, and disconnect from any external power source.
Wat je nodig hebt
Gereedschap
  1. Acer Aspire V5-131-2680 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Turn the Acer Aspire upside down, with the stickers facing up.
    • Unplug the charger and make sure the device is off.
  2. Acer Aspire V5-131-2680 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the twenty M2 x 6 screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the opening tool.
  3. Acer Aspire V5-131-2680 Motherboard Replacement: stap 3, afbeelding 1 van 3 Acer Aspire V5-131-2680 Motherboard Replacement: stap 3, afbeelding 2 van 3 Acer Aspire V5-131-2680 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the two components that are attached to the motherboard and keyboard.
    • The large ribbon cable is disconnected by pulling apart the two white tabs found on each side of the connection and lifting the cable out.
    • The small wire can be removed by simply pulling on the blue tape
  4. Acer Aspire V5-131-2680 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the three M2 x 3 Phillips screws on the motherboard.
  5. Acer Aspire V5-131-2680 Motherboard Replacement: stap 5, afbeelding 1 van 3 Acer Aspire V5-131-2680 Motherboard Replacement: stap 5, afbeelding 2 van 3 Acer Aspire V5-131-2680 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Disconnect all the big and small wires connected to the motherboard.
    • The big wires must be squeezed on each side of the connection to release the tabs, then pull the cable out.
    • The small wires can be removed simply by pulling the cable out of the connection
  6. Acer Aspire V5-131-2680 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently pull the motherboard up and to the right at the same time.
  7. Acer Aspire V5-131-2680 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Once the motherboard is out, take off the tape that is holding the fan and the motherboard together. Push the fan down and it will come off.
Conclusie
Mauricio Moreno
601 Reputatie
5 handleidingen geschreven
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 322
