Ga door naar hoofdinhoud
Acer Aspire V5-131-2629 RAM Replacement
Nicholas Vassiliadis
Nicholas Vassiliadis en 4 andere bijdragers
Voor het laatst geüpdatet op April 25, 2022
5 minuten
Eenvoudig
This guide will provide in-depth instructors on replacing or removing the RAM in an Acer Aspire V5-131-2629 laptop.
Is your laptop slow and sluggish while performing small tasks? Replacing and upgrading your RAM can increase the speed of your laptop for easy multitasking. Getting more RAM will boost the overall performance of your laptop. Follow this simple 6 step guide to replace your RAM and give your computer a boost in no time!
Unfortunately, the Acer website has taken down information regarding this device. However, a basic, rather informal summary of the details and specs can be found at the following link:
++Acer Aspire V5-131-2629 prices and specs++
A general disassembly tutorial of the device can be found:
++How to Disassemble the Acer Aspire V5 131++
Outside Resources-
The link to replacement RAM can be found at:
++Acer Aspire V5 131-2629 RAM Replacement++
Wat je nodig hebt
Gereedschap
  1. Acer Aspire V5-131-2629 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 RAM Replacement: stap 2, afbeelding 1 van 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 RAM Replacement: stap 3, afbeelding 1 van 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 RAM Replacement: stap 4, afbeelding 1 van 2 Acer Aspire V5-131-2629 RAM Replacement: stap 4, afbeelding 2 van 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 RAM Replacement, Cover: stap 5, afbeelding 1 van 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 RAM Replacement: stap 6, afbeelding 1 van 2 Acer Aspire V5-131-2629 RAM Replacement: stap 6, afbeelding 2 van 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 RAM Replacement, RAM: stap 7, afbeelding 1 van 1
    • Using your finger, press the small tab on each side of the memory card.
    • The memory card will eject at a 45 degree angle.
  8. Acer Aspire V5-131-2629 RAM Replacement: stap 8, afbeelding 1 van 1
    • Pull the memory cards out from the laptop.
Conclusie
85 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 697
