Ga door naar hoofdinhoud
Acer Aspire One D255E Keyboard Replacement
Brian
Brian en een andere bijdrager
Voor het laatst geüpdatet op September 16, 2019
Geen schatting
Gemiddeld
The keyboard is the most essential input component on a laptop. Though this component is designed to have frequent usage either with old age or bad treatment this component may have to be replaced. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: stap 2, afbeelding 1 van 2 Acer Aspire One D255E Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 1 van 3 Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 2 van 3 Acer Aspire One D255E Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brian
1.302 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 2,461
