Acer Aspire One D255E Back Panel Replacement
Inleiding
Ga naar stap 1Though the back panel is not itself a component that is often replaced you will need to remove it in order to get to various components inside the computer. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Wat je nodig hebt
Gereedschap
