Ga door naar hoofdinhoud
Abask J05 Battery Replacement
Wat je nodig hebt
  1. Abask J05 Battery Replacement, Front Case: stap 1, afbeelding 1 van 2 Abask J05 Battery Replacement, Front Case: stap 1, afbeelding 2 van 2
    • Gently press on the SD card with a fingernail until it clicks.
    • Release, then remove the card.
    Vraag FixBot
    Voeg opmerking toe
  2. Abask J05 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5 mm screw from the side of the device next to the suction cup dock with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Abask J05 Battery Replacement: stap 3, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 8 mm screws from opposite sides of the screen with a Phillips #00 precision screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Abask J05 Battery Replacement: stap 4, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently lift the screen.
    • Push up on the interior camera portion of the device. It should pop out of the socket. Being careful to keep the wires attached, set it to the side.
    Vraag FixBot
    Voeg opmerking toe
  5. Abask J05 Battery Replacement: stap 5, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 5, afbeelding 2 van 2
    • Reach into the device with a spudger to release the top two snap joints keeping the end cap attached one at a time until the front face lifts off.
    • Be careful not to touch the screen.
    • Repeat the process with the two remaining snap joints.
    Vraag FixBot
    Voeg opmerking toe
  6. Abask J05 Battery Replacement, Screen: stap 6, afbeelding 1 van 2 Abask J05 Battery Replacement, Screen: stap 6, afbeelding 2 van 2
    • Remove the two 7 mm screws on the side of the motherboard with a Phillips #00 screwdriver.
    • Slowly pull up on each corner of the motherboard, stopping when the corner pops loose of the anchor.
    • Repeat the process with each corner before slowly pulling up on the board to detach the glue on the underside.
    Vraag FixBot
    Voeg opmerking toe
  7. Abask J05 Battery Replacement: stap 7, afbeelding 1 van 3 Abask J05 Battery Replacement: stap 7, afbeelding 2 van 3 Abask J05 Battery Replacement: stap 7, afbeelding 3 van 3
    • Carefully flip over the motherboard, being mindful of the wires.
    • Remove the two 5mm screws on the underside of the motherboard with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Abask J05 Battery Replacement: stap 8, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 8, afbeelding 2 van 2
    • Follow the golden ribbon from the screen to the screen dock. Push the two small black stubs on either side of the dock away from the dock until it pops loose.
    • Remove the ribbon and the small plastic piece from the dock.
    Vraag FixBot
    Voeg opmerking toe
  9. Abask J05 Battery Replacement: stap 9, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 9, afbeelding 2 van 2
    • Gently pull up on each corner of the white screen piece until the adhesive comes loose.
    • Remove the screen fully from its holder.
    Vraag FixBot
    Voeg opmerking toe
  10. Abask J05 Battery Replacement, Motherboard: stap 10, afbeelding 1 van 3 Abask J05 Battery Replacement, Motherboard: stap 10, afbeelding 2 van 3 Abask J05 Battery Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Desolder the red wire attached to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Abask J05 Battery Replacement: stap 11, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 11, afbeelding 2 van 2
    • Detach the ribbon cable connecting the motherboard to the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  12. Abask J05 Battery Replacement: stap 12, afbeelding 1 van 2 Abask J05 Battery Replacement: stap 12, afbeelding 2 van 2
    • Desolder all four wires connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. Abask J05 Battery Replacement: stap 13, afbeelding 1 van 1
    • Remove the motherboard from the device.
    Vraag FixBot
    Voeg opmerking toe
  14. Abask J05 Battery Replacement, Battery: stap 14, afbeelding 1 van 2 Abask J05 Battery Replacement, Battery: stap 14, afbeelding 2 van 2
    • Heat the iOpener as instructed, then place it over the battery.
    • Check periodically to see whether the glue has melted.
    • This should take about 5-15 minutes.
    Vraag FixBot
    Voeg opmerking toe
  15. Abask J05 Battery Replacement: stap 15, afbeelding 1 van 3 Abask J05 Battery Replacement: stap 15, afbeelding 2 van 3 Abask J05 Battery Replacement: stap 15, afbeelding 3 van 3
    • Peel off the tape on the battery.
    • Remove the battery from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. (Note: When doing the steps in reverse order, do not do Step 5. Instead, place the front face of the device back on the main body before lining up the endcap, ensuring proper orientation with the SD card slot, and push in until you hear all four snap joints snap into place.)
Één andere persoon heeft deze handleiding voltooid.
Valerie Kulnar
680 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 519
