Ga door naar hoofdinhoud
ASUS X550LB-DS71 Display Panel Replacement
Nathan Dyer
Nathan Dyer en 3 andere bijdragers
Voor het laatst geüpdatet op December 26, 2017
20 minuten
Gemiddeld
The display monitor is an output device which presents data on the screen. It is what allows the user to see what inputs they are putting into the device.
Wat je nodig hebt
Gereedschap
  1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: stap 1, afbeelding 1 van 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: stap 1, afbeelding 2 van 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: stap 1, afbeelding 3 van 3
    • Flip open the laptop with the screen facing towards you.
    • Using the plastic opening tool, remove the square tape from the marked locations.
    • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
  2. ASUS X550LB-DS71 Display Panel Replacement: stap 2, afbeelding 1 van 2 ASUS X550LB-DS71 Display Panel Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tool, open the front cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  3. ASUS X550LB-DS71 Display Panel Replacement: stap 3, afbeelding 1 van 3 ASUS X550LB-DS71 Display Panel Replacement: stap 3, afbeelding 2 van 3 ASUS X550LB-DS71 Display Panel Replacement: stap 3, afbeelding 3 van 3
    • Peel off the tape located on the left and right side of the display monitor.
    • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
  4. ASUS X550LB-DS71 Display Panel Replacement: stap 4, afbeelding 1 van 3 ASUS X550LB-DS71 Display Panel Replacement: stap 4, afbeelding 2 van 3 ASUS X550LB-DS71 Display Panel Replacement: stap 4, afbeelding 3 van 3
    • Place the display monitor face down to expose the ribbon connector.
    • Remove the ribbon connector to separate the display monitor from the rest of the device.
Conclusie
Nathan Dyer
550 Reputatie
5 handleidingen geschreven
USF Tampa, Team S16-G1, Eyestone Fall 2017 Lid van USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 1,105
