ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
Inleiding
Ga naar stap 1The keyboard and touch pad are contained within the palm rest. If you are experiancing problems with the keyboard or the touch pad and need to replace one of them, you will need to replace the entire palm rest with keyboard and touch pad.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
5 andere personen hebben deze handleiding voltooid.
Één opmerking
there is no reason to disassemble the top-half of the laptop.
