Ga door naar hoofdinhoud
ASUS ROG Spatha X Scroll Wheel Replacement
Wat je nodig hebt
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: stap 1, afbeelding 1 van 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: stap 1, afbeelding 2 van 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: stap 1, afbeelding 3 van 3
      • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
      • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
      • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS ROG Spatha X Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 ASUS ROG Spatha X Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
      • Lift the upper mouse cover up and off.
      Vraag FixBot
      Voeg opmerking toe
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: stap 3, afbeelding 1 van 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: stap 3, afbeelding 2 van 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: stap 3, afbeelding 3 van 3
      • Remove the Phillips screw securing the ribbon cable scroll wheel.
      • Disconnect the ribbon cable from the scroll wheel.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS ROG Spatha X Scroll Wheel Replacement: stap 4, afbeelding 1 van 3 ASUS ROG Spatha X Scroll Wheel Replacement: stap 4, afbeelding 2 van 3 ASUS ROG Spatha X Scroll Wheel Replacement: stap 4, afbeelding 3 van 3
      • There is a plastic axle holding the scroll wheel in place. It is cinched into a plastic housing unit towards the right side of the mouse (towards the pinky rest).
      • Use one hand to gently pull the housing for the axle away from the scroll wheel as you simultaneously use the other hand to pull up and away from the housing unit.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
678 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-4, Botvin Spring 2025 Lid van UMass Dartmouth, Team 3-4, Botvin Spring 2025
UMASSD-BOTVIN-S25S3G4
3 Leden
15 handleidingen geschreven
1Gids Commentaar
Easy replacement but good luck finding the part. It's not sold ANYWHERE.
Tyler Pratt - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 130
Altijd: 1,218
