Ga door naar hoofdinhoud
APC Smart-UPS SRT30000XLA Battery Cells Replacement
Wat je nodig hebt
  1. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, unplug your UPS.
  2. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the front bezel: stap 2, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the front bezel: stap 2, afbeelding 2 van 2
    • Plastic clips secure the front bezel.
    • Pull the left edge of the front bezel away from the device to release the plastic clip.
  3. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 3, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 3, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 3, afbeelding 3 van 3
    • Continue pulling the left edge of the front bezel away from the device until the right clip releases.
    • Remove the front bezel.
  4. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Disconnect the battery: stap 4, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Disconnect the battery: stap 4, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Disconnect the battery: stap 4, afbeelding 3 van 3
    • Use the cutout in the battery connector to pull it toward the right edge of the device and disconnect it.
  5. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the battery connector: stap 5, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the battery connector: stap 5, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the battery connector: stap 5, afbeelding 3 van 3
    • Lift and rotate the battery connector to move it out of the way of the battery assembly.
  6. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unfasten the battery assembly: stap 6, afbeelding 1 van 1
    • Use a Phillips driver to remove the three 23 mm‑long screws securing the battery assembly.
  7. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the battery assembly: stap 7, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the battery assembly: stap 7, afbeelding 2 van 2
    • Pull the battery assembly out of the housing until it stops at its first plastic tab.
    • You'll feel the assembly stop abruptly and hear the plastic tab "click."
  8. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 8, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 8, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 8, afbeelding 3 van 3
    • Depress the plastic tab while pulling on the battery assembly until it clears the tab.
  9. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 9, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 9, afbeelding 2 van 2
    • Continue pulling the battery assembly out of the housing until it stops at its second plastic tab.
  10. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 10, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 10, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 10, afbeelding 3 van 3
    • Depress the plastic tab while pulling on the battery assembly until it’s free from the housing.
  11. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the covers: stap 11, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the covers: stap 11, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the covers: stap 11, afbeelding 3 van 3
    • Peel off any screw covers from the top of the battery assembly.
  12. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unfasten the top shell: stap 12, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unfasten the top shell: stap 12, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unfasten the top shell: stap 12, afbeelding 3 van 3
    • These screws are very tight and easily strip. Apply constant downward pressure to avoid stripping them.
    • Use a Triangle 3 driver to remove the six screws securing the battery assembly's top shell:
    • Four 22.7 mm-long screws
    • Two 15 mm-long screws.
  13. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unclip the top shell: stap 13, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unclip the top shell: stap 13, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Unclip the top shell: stap 13, afbeelding 3 van 3
    • The top shell of the battery assembly is secured with a plastic clip.
    • Depress the plastic tab above the battery connector and lift up the top shell to release the clip.
  14. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 14, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 14, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 14, afbeelding 3 van 3
    • The back of the top shell is secured with tape. Be careful to not peel the tape off during this step.
    • Swing the top shell over the battery assembly and lay it down.
  15. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Battery information: stap 15, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Battery information: stap 15, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Battery information: stap 15, afbeelding 3 van 3
    • If any battery cells are leaking or showing signs of corrosion, put on nitrile gloves to protect your hands.
    • The next five steps demonstrate how to remove any one battery cell. The battery cells are identical, but the connector positions vary.
    • During reassembly, refer to these photos to reconnect the batteries properly.
  16. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the wire: stap 16, afbeelding 1 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the wire: stap 16, afbeelding 2 van 3 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Reposition the wire: stap 16, afbeelding 3 van 3
    • If a light red wire is covering the battery cell you're working on, you’ll need to move it out of the way.
    • Lift the light red wire out of its spot next to the screw post to access the connector beneath.
    • During reassembly, make sure the wire is put back in its original spot or else the top shell won't close properly.
  17. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Disconnect the battery cell: stap 17, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Disconnect the battery cell: stap 17, afbeelding 2 van 2
    • Grip the white spade connector and pull up to disconnect it from the negative terminal of the battery cell.
    • Always pull on the connector itself, not the wire.
  18. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 18, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 18, afbeelding 2 van 2
    • Repeat for the other spade connector attached to the positive terminal of the battery cell.
  19. APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the battery cell: stap 19, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement, Remove the battery cell: stap 19, afbeelding 2 van 2
    • Lift the battery cell out of its housing and remove it.
  20. APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 20, afbeelding 1 van 2 APC Smart-UPS SRT30000XLA Battery Cells Replacement: stap 20, afbeelding 2 van 2
    • If you own a multimeter, you can determine the battery cell's health by measuring its voltage.
    • Follow this guide to use a multimeter and measure voltage using these parameters:
    • If your battery cell's voltage is less than 10 V, replace it.
    • Charge the entire battery assembly to 100% and test the cell again. If your battery is less than 12 V, replace it.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our APC Smart-UPS SRT30000XLA Community for help.
Alex Diaz-Kokaisl
163.708 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.643 handleidingen geschreven
1Gids Commentaar
أحسنت الشرح
Ahmed Shabaan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 37
Altijd: 336
