Ga door naar hoofdinhoud
ANKER SoundCore Battery/Battery Wire Replacement
Wat je nodig hebt
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: stap 1, afbeelding 1 van 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: stap 1, afbeelding 2 van 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
    Vraag FixBot
    Voeg opmerking toe
  2. ANKER SoundCore Battery/Battery Wire Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
    Vraag FixBot
    Voeg opmerking toe
  3. ANKER SoundCore Battery/Battery Wire Replacement: stap 3, afbeelding 1 van 3 ANKER SoundCore Battery/Battery Wire Replacement: stap 3, afbeelding 2 van 3 ANKER SoundCore Battery/Battery Wire Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
    Vraag FixBot
    Voeg opmerking toe
  4. ANKER SoundCore Battery/Battery Wire Replacement: stap 4, afbeelding 1 van 3 ANKER SoundCore Battery/Battery Wire Replacement: stap 4, afbeelding 2 van 3 ANKER SoundCore Battery/Battery Wire Replacement: stap 4, afbeelding 3 van 3
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
    Vraag FixBot
    Voeg opmerking toe
  5. ANKER SoundCore Battery/Battery Wire Replacement: stap 5, afbeelding 1 van 1
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Lucas Sandsor
313 Reputatie
1 Handleiding geschreven
Cal Poly, Team S22-G1, Regan Winter 2020 Lid van Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Leden
12 handleidingen geschreven
6Gids Commentaar
If a bt speaker battery died,the unit can't power up by cable?
limz555 - Antwoord Deel
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - Antwoord Deel
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - Antwoord Deel
Where do I get the new battery in India?
Raghubir Roy L - Antwoord Deel
What are the specs on the battery, so I can double-check compatibility for a replacement?
Andy Mattson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 410
Altijd: 32,315
